Turn/Hazard Signals Not Working (and alot more issues) - 95 850 T5-5
Old Sep 26, 2008 | 12:34 PM
schwing's Avatar
Default Turn/Hazard Signals Not Working (and alot more issues) - 95 850 T5-5
Ok, I just bought a 1995 850 T5-R a few days ago, and I have been trying to figure out some issues with it.
1.) The turn/hazard signals are not functioning. Headlights work both High and Low beams.
2.) When I turn my car on at night, my instrument panel will light up as well as my shifting column. But after about 1-3 seconds, they will kick off and everything in the car will be dark.
3.) Does anyone have a recommendation of a good interior repair person in Southern Cal (I just moved out here), I would like to get the roof interior replaced, and the drivers seat has separated in the middle of where the bum goes
4.) Does the 95 T5-R use a regular OBD-II computer or does it need a special volvo OBD-II?
Thanks for for your time
-Schwing
Old Sep 26, 2008 | 07:50 PM
Default RE: Turn/Hazard Signals Not Working (and alot more issues) - 95 850 T5-5
1. Maybe the hazard switch is bad. Also check all fuses.
2. My bet is the dimmer switch is bad.(I had to replace mine after I got it)
3. Sorry live in FLA.
4. On the 95 the OBDII only reads engine codes. You have to use the OBDI under the hood for the rest of the systems.
Old Sep 26, 2008 | 11:25 PM
Psaboic's Avatar
Follow Tech's suggestions.....he knows what he is talking about.
Old Sep 29, 2008 | 11:30 AM
schwing's Avatar
Well so far I have found that when I turn my headlamps on and switch to the high beam and then use the rocker switch for the hazards, it will allow for my turn signals to start working again.
Old Sep 30, 2008 | 08:38 AM
Psaboic's Avatar
That tells me that the bulbs, wiring, and flasher unit are all good. Having the headlights on high-beam should not make any difference. Therefore, I am starting to suspect that the turn signal switch on the steering column might be the issue.
Old Sep 30, 2008 | 06:47 PM
It could also still be the hazard switch.
Old Oct 1, 2008 | 08:36 AM
Psaboic's Avatar
Thats true! I always forget about hazard switches.
pinkzambia
Nov 12, 2014 01:11 PM
hu5ker555
Jul 12, 2013 08:59 AM
hobbitwho
Nov 22, 2010 08:27 AM
efatsi
Mar 16, 2010 02:46 AM
Ked
Nov 9, 2009 09:27 PM
