Turn signals not working
Old Oct 5, 2009 | 02:40 PM
efatsi's Avatar
Default Turn signals not working
Hey,
On my 1990 240 wagon, I've replaced the turn signal switch, the flasher, and the fuse multiple times but the fuse gets blown whenever the car is running. The turn signals will work for hours if the car is not on, but with the engine running a fuse will only last a couple of minutes before it gets blown. Any thoughts?
Thanks,
-Eli
Old Oct 5, 2009 | 03:10 PM
bubba240's Avatar
That fuse is shared with the back-up lights, so you might try putting it into reverse with the car off, key on and see if it blows.
Old Mar 15, 2010 | 12:07 PM
preston's Avatar
Were you able to find out what the problem was? I am having a similar problem with my 240
Old Mar 16, 2010 | 02:46 AM
efatsi's Avatar
Water was leaking into my car and doing some damage. I got the fuse box cleaned up and just bought a bunch of fuses to fix the problem. Every other month or so they stop working, and a good jiggle on the fuse itself will fix it. Good luck with yours!
hu5ker555
Jul 12, 2013 08:59 AM
'88volvo240DLdriver
May 28, 2012 07:56 PM
hobbitwho
Nov 22, 2010 08:27 AM
Ked
Nov 9, 2009 09:27 PM
