'88 240 DL turn signals working intermittently
Old May 21, 2012 | 07:24 PM
'88volvo240DLdriver's Avatar
Default '88 240 DL turn signals working intermittently
So, my blinkers stopped working all together so I replaced the bulbs and the fuse and voila... Fixed!
Uh, nope. only worked for a few weeks...
Now the left blinker only blinks once, maybe 2x and the R blinker works sometimes or only blinks a few times before stopping. If I hold the blinker arm "in between" the on/off position, I can sometimes get it to blink a tad longer.
It's dangerous not having properly functioning blinkers... I'd like to fix this right away. Is it the relay? The wiring? Do I need to replace the whole wiring unit? And if so, where is the best place to obtain these parts for an 88 240 DL? I have no idea where these parts are. The manual is very confusing.
Any help is very much appreciated.
thank you!
Old May 22, 2012 | 06:57 AM
sicnarf's Avatar
I think the fault could be in the blinker arm. Just screw open the arm and see if you can see some fault in the wiring.
Old May 22, 2012 | 04:51 PM
anyone else have any ideas? Where is the location of the relay switch? Where can I buy a new one for this old beaut? Thanks!
p.s. Going to look at the arm, but wanting to figure out plan B and C if that's not it.
Old May 22, 2012 | 05:28 PM
I could tell you where the blinker relay is on a 740 and 940, but I'd have to look up where it is on a 240.
Bentley says its to the right of the driver side foot well, just above the transmission hump, and behind the lower stereo/amplifier/equalizer mounting position.
this guy concurrs... http://www.davebarton.com/pdf/relay_87_240.pdf
Old May 23, 2012 | 05:20 PM
thanks everyone! I'll let you know how this shakes out.
Old May 26, 2012 | 08:47 AM
zjinqui1k's Avatar
So, your problem may be unrelated to this, but, this side note may help--Many intermittent electrical problems I have found to be connected to the fusebox. I clean and sand the fuse and contacts for the tricky area, and magically things start working again. I don't know what it is about those style fuseboxes, but they are prone to oxidization. So even if I have previously replaced fuses, I often clean them up again before I move on to other things--it is easy to rule out and nice if it is the problem.
Old May 28, 2012 | 07:56 PM
also, for the 240 'ceramic' style fuses, get the copper/brass ones... there's a vendor on ebay who sells a kit of way more than enough fuses, he targets this for Mercedes W124 chassis cars that used these (late 80s 300E family).
spozag
Nov 29, 2014 02:55 PM
DavePeeb
May 23, 2010 03:32 AM
efatsi
Mar 16, 2010 02:46 AM
Ked
Nov 9, 2009 09:27 PM
