2000 xc70 trans
Old Sep 10, 2016 | 03:21 PM
humncummins's Avatar
Default 2000 xc70 trans
2000 xc 70 226k no reverse all forward gears work fine fluid is good when I put it in reverse I can feel it go in but it won't move.
Old Sep 12, 2016 | 10:00 PM
when you say "fluid is good" do you mean full or a good color (not black/burnt smell)?
Do the back up lights come on when you put it in reverse?
Three ways this can go - 1) you have a shifter issue, possibly in the PNP switch 2) you have a burnt transmission fluid/possible bits getting in the way of the solenoid valves. A drain/fill or flush may help or consider dropping the pan to inspect for loose bits 3) your transmission has internal damage and its time to replace the transmission or part out the car...
rrob311
1998-2000 model year XC70
Nov 11, 2013 06:56 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
