2001 C70 Starting Problem
My C70 has developed an intermittent start and die problem; it starts, starts to go to high-idle, then dies. If I cycle the key off and then back on, crank it, cycle off and on again, it will start and promptly die as it hits high idle (cold engine - mostly). When I go through this ritual the third time it usually stays running. Since it is intermittent and a recent development, I'm at a loss. Any suggestions?
Do you have another key you can try?
Also try turning the key on and off a few times before starting it and see if that helps. If it does then for some reason the fuel is bleeding back to the tank.
