Starting/power problem on 2001 S80
Old Nov 17, 2011 | 01:42 PM
magicmule's Avatar
Default Starting/power problem on 2001 S80
Now that the weather has cooled off, i am starting to have a problem with my S80. One early morning I came to start my car and it wouldnt turn over, i just get clicks from under the dash. I put it on charge of an hour and all worked fine. Since then i sometimes get a clicking sound in the morning briefly before starting. It has started though and I find that the clock is reset and sometimes the power opener on the doors dont work, i have to use the remote.
What could be wrong?
Old Nov 17, 2011 | 07:03 PM
537playing's Avatar
It sounds like a weak battery. When was it replaced? Or perhaps the alternator is starting to fail.
Old Nov 18, 2011 | 01:40 PM
Falasi4's Avatar
Unhappy
+1 on the battery needing to be replaced.
beware - disconnecting the positive terminal first may (very likely) trip your airbag warning which can only be reset with an airbag reset tool for about $60-100.
If memory serves - someone please verify this - disconnect the negative terminal first on these.
fyi: I got a new battery this summer and found this out the hard way
Kathleen Higgins
Sep 22, 2013 05:44 PM
DanSC
Jul 5, 2013 08:34 AM
Venturbo
Oct 2, 2009 04:34 AM
nanawrench
Jul 12, 2009 08:52 AM
dkvcopy
Mar 23, 2008 06:04 AM
