2006 s40 blowing ignition coil fuse
Old Jan 2, 2020 | 07:03 PM
Lee Patrick's Avatar
Default 2006 s40 blowing ignition coil fuse
Why does it keep blowing fuse 34 after changing timing belt? It’ll crank but won’t start, blows fuse every time. Checked marking on timing belt several times.
Old Jan 3, 2020 | 09:52 AM
are you saying this only happened after you did the timing belt? I suspect you nicked a wire and its shorting out or a sensor component is drawing too much current. Not sure what's close to where you were working but perhaps its related to the AC system since the pressure sensors are on fuse 34 as well.
faulknh88
Apr 8, 2017 11:44 PM
jclem06
Aug 4, 2013 06:24 PM
jimuck
2001-2013 model year V70
Sep 4, 2012 05:12 AM
JRT325
Aug 25, 2012 11:46 PM
collslee
Mar 2, 2011 05:19 PM
