'94 850 Volvo starting issues and white smoke
Old Apr 9, 2014 | 02:22 AM
elhvolvo's Avatar
Exclamation '94 850 Volvo starting issues and white smoke
Sure hope someone can help…have an 850 non-turbo volvo that is having lagging issues in starting, mostly cranks and just as I'm about to give up, engine turns over, this has been going on for the last 2 weeks. I, sometimes am seeing white smoke coming from back end.
Idle also seems running a bit higher i.e. I have a sports and econ mode to drive and its like I'm driving in the sports mode(just sounds louder and rougher). At 25/35 mph seems to be running at a higher idle than normal. BTW have also had key issues with my ignition seems as if key is getting difficult to insert and was told that eventually the pin my drop and I will either not be able to insert or remove key. Therefore, I have key inserted always and am using a club. Not sure if there is any correlation. Any ideas or suggestions?
Last edited by elhvolvo; Apr 9, 2014 at 02:43 AM. Reason: trying to delete added message in new members thread
elhvolvo
Apr 9, 2014 10:44 AM
Megadiesel
Oct 24, 2009 09:59 PM
janalco
Mar 27, 2008 06:37 PM
83Murdered850
Jan 25, 2008 09:22 PM
logroll1
Nov 13, 2007 06:20 PM
