'98 V70 Electrical Woes
Old Sep 8, 2013 | 04:06 PM
AveryOttawa's Avatar
Default '98 V70 Electrical Woes
Evening, all.
Brand new here and need a little help. Please see video outlining electrical trouble. She won't turn or even click.
Cheers.
Old Sep 8, 2013 | 07:08 PM
Dead/bad battery. What makes you think the battery is good?
Old Sep 9, 2013 | 05:18 AM
I figure it would have at least acted differently when hooked up to another car via cables if it were the battery.
Old Sep 10, 2013 | 12:47 PM
Pete-FWA's Avatar
First thing is to test that battery properly, either with a load tester or at least a voltmeter. Unhook the cables and go directly from the posts of the battery.
If that truly tests OK, now the search for a faulty connection is next. Check the post connectors, look for corrosion on the ground, look for starter wires being loose, corroded, or otherwise compromised.
ptrick
Jun 10, 2015 01:13 PM
purplexus
Dec 6, 2011 09:02 PM
medufour
Jul 3, 2007 07:48 PM
sghokie
Sep 26, 2006 01:35 AM
haygoog
Jun 8, 2006 06:28 PM
