99 S70 driver side wheel seems loose...help
Old May 6, 2008 | 03:40 PM
matrup1's Avatar
Default 99 S70 driver side wheel seems loose...help
My 99 S70 has 120000 miles. The driver side wheel seems loose when I kick the tire, but the lugs are tight. Do you think my CV joint is bad or do I have a bearing issue? Does anyone have a website with how to info for Volvos, especially 98-99's S70? I can't find a repair manual locally.
Any help would be appreciated!
Matrup
Old May 7, 2008 | 06:25 AM
JPN's Avatar
JPN
Default RE: 99 S70 driver side wheel seems loose...help
If the lug bolts are tight, it could be:
- Retiring ball joint (this has to be replaced with the control arm as they are one unit).
- Retiring tie-rod end.
- Retiring bearing hub assy (if it's making noise)
- Retiring control arm bushing (not too common).
- Loose hub nut (not too common unless someone fiascoed it upon installation)
Usually, a retiring CV-joint would not make the wheel loose but is noticed by clicking at turns.
http://www.amazon.com/s/ref=nb_ss_gw...+repair+manual
The Haynes ver. seems to cover '99. Chilton seems to cover only up to the '98 models.
JPN
1995Volvo850
Oct 25, 2012 10:06 PM
tdrendel
Apr 11, 2012 06:32 PM
epgiles
Apr 6, 2009 06:59 AM
akb1274
Dec 16, 2008 12:38 PM
bullet
Jan 24, 2007 08:42 PM
