Clicking Driver Door (loose window)
Old Oct 24, 2012 | 09:34 PM
1995Volvo850's Avatar
Default Clicking Driver Door (loose window)
So, if I shut my driver door when the window is down, it clicks/rattles abnormally loud, something none of the other doors do. If I roll my window up half way up before I close the door, the sound doesn't happen.
I have been told I have some sort of broken window guide or something in the door, but I am not sure exactly what the problem is. If I roll my window up half way up before I close the door, the sound doesn't happen.
Is this a common issue? If so, what is the suspect and the recommended fix?
Thanks in advance!
1995Volvo850
Old Oct 25, 2012 | 09:29 AM
Not a common problem. You can go into the panel and see if something is loose.
http://atthetipwebs.com/technologyin...door_panel.htm
Old Oct 25, 2012 | 02:01 PM
MattyXXL's Avatar
Its the lower rail for the window, if you dont want to replace it just take your door panel off and pull the rail out...
Volvo Window Regulator Rail Front Left (850 S70 V70) Genuine Volvo 9187646 | FCP Euro
Old Oct 25, 2012 | 10:06 PM
Thanks! Is it the actual window or the rail (or both) rattling? What purpose does this part serve? What should I be careful of if I totally remove it? Is it true that if I continue to close the door with the window down (or with the rail removed), it could break the window?
muckster
Dec 31, 2014 12:56 PM
Ovlov NB
Aug 21, 2009 06:51 PM
davidzisa
Mar 20, 2009 09:24 AM
matrup1
May 7, 2008 06:25 AM
bullet
Jan 24, 2007 08:42 PM
