ABS Tracs light
Old Mar 3, 2008 | 02:55 PM
850fixer's Avatar
Default ABS Tracs light
The ABS,Tracs lights are on on my 1996 850r wagon. The speedometer and cruise does not work either. I read up on the forums and repairing the ABS module should fix the problem. Took off and sent in for repair. Reinstalled when returned and when I plug in the connector the 30 amp fuse for the ABS module blows ASAP. Left the pump connector unplugged and still blows fuse. Suggestions??????
Old Mar 3, 2008 | 06:59 PM
Default RE: ABS Tracs light
Resend back and have them look it over to make sure they didn't mess the module up.
Sounds like it is shorted internally.
Old Mar 7, 2008 | 06:07 AM
johnpoach's Avatar
Ihave the same problem on my v70. abs and tracks lights come on after a few miles and stay on all the time then, but the machine in the garage said,No fault found, I will have a look under there myself this weekend, all brakes work perfect, but these things are set to try us arent they,John.
Old Mar 7, 2008 | 08:28 AM
jks2's Avatar
Your brakes will work with the ABS Tracs lights on, you just wont have the anti lock function. You may also notice some rapid pumping intermittently. You can drive the car while the ABS module is off the car (again no ABS) I would send the module for repair. I used BBA Remanufacturing to have mine fixed. No problems.
shoter_hellas
Nov 27, 2011 11:06 PM
paulh
Jan 30, 2008 08:22 PM
jack2403
Jan 4, 2007 08:43 PM
Buck
Aug 11, 2006 12:56 AM
vwown3d
Aug 20, 2005 03:01 PM
