antilock brake sensor problems
Old Feb 15, 2009 | 03:11 PM
repairmantommy's Avatar
Talking antilock brake sensor problems
go check under the hood for a connector on passenger side ( right ) next to coolant tank & shock absorber tower mount, under the hood support for a broken abs wire on that connector, ti can happen mearly by closing the hood on this connector.
1989 760
Old Mar 13, 2009 | 10:28 PM
drewtiss's Avatar
Originally Posted by repairmantommy
go check under the hood for a connector on passenger side ( right ) next to coolant tank & bmw shocks absorber tower mount, under the hood support for a broken abs wire on that connector, ti can happen mearly by closing the hood on this connector.
1989 760
Okay. Now, what should I do after I see some broken abs wire on that connector? I'm still a noob at this point.
Old Mar 14, 2009 | 02:40 PM
Default fixing wires on volvo's
take a cigarette lighter & heat wire & roll back wire sheathing enough to twist the wires together & solder them if you have knowledge of how to solder, if not just twist them together real tight & tape them very well. if by chance the wire is broke off right at the connector, you will have to solder wire to the connector in the plug to ensure proper connection. if need be take it to electronics repairshop, 1 of the guys would probably be glad to help you fix your broken wire, this would save you hundreds of dollars at a repair shop.
keep patching together those pesky broken wires & keep driving.
Freestate
Dec 10, 2014 06:20 PM
twoarcadians-volvo
May 17, 2011 10:44 AM
repairmantommy
May 20, 2009 12:38 PM
robretpd
Sep 22, 2007 05:12 PM
Frodo
May 29, 2006 12:07 PM
