Cracked Valve Cover
Old Apr 30, 2020 | 07:12 AM
RandyD56's Avatar
Default Cracked Valve Cover
I have a 2013 S60 and I discovered I have a cracked valve cover. First, I didn’t think these could crack and second, can I drive to have it repaired or should I have it towed? Thanks.
This is weird.
Old Apr 30, 2020 | 03:55 PM
which engine? that's the engine's "appearance cover". You're not leaking oil or anything right? Did you try removing it to see if anything else is damaged?
Old May 1, 2020 | 12:30 AM
RandyD56's Avatar
Default Cracked Engine Cover
It is the T5. I have not gotten any leaks that I can tell. The low coolant light is the only thing that has happened. What do you think? The piece is only $50.00 to replace. It couldn’t be much important from the cost. This has worried me a great deal.
Old May 1, 2020 | 09:54 AM
thats a trim piece to cover the coils/spark plugs etc. Its not a "valve cover" in the sense of an old school V8. What needs to be looked into is why your coolant level is down. Could be a small leak in a hose etc. Also you should be doing a coolant refresh every 5 years so if that hasn't been done for your car yet, you can have the shop do a pressure test to see if there's a slow leak to address, then refresh the coolant.
KRH
Oct 17, 2017 02:52 PM
Shawnsown
Nov 26, 2013 07:06 PM
mwhitehead530
Oct 24, 2009 09:38 AM
Sofar.
Mar 25, 2009 12:45 AM
bigdaddyrdpjr
Sep 23, 2007 05:29 PM
