Does spark plug reach matter much?
Old Nov 23, 2017 | 08:03 AM
pyro71's Avatar
Default Does spark plug reach matter much?
I would think that spark plug reach is a major concern. What if I had 05 s60 2.5t. and I had a champion double plat 7975 plug. When measured next to a ngk g power bkr6egp the champion is about 5/16 longer. Is this ok or is it terrible?? I cross ref this champion plug to a denso and utolite plug. It stated that those two plugs were not for my car. I'm wondering if the champion plug is not for my car... although champion says it is.
Old Nov 23, 2017 | 10:36 AM
madman77's Avatar
Yes, reach does matter, especially 5/16 of an inch. It could interfere with the piston or even the valves. Too short and it will not ignite the fuel mixture.
I would not recommend Champion plugs, they fail quite a lot. IMHO Denso is your best bet.
Old Nov 24, 2017 | 12:10 PM
+1 on getting the exact correct reach. That is important. Not sure if I agree on Denso vs Champion. Both have many styles - best to stick close to what the OEM design is and more expensive is not necessarily better (in fact the older turbos like my 850T run best on the copper core plugs). Its easy enough to shop online for the correct part number with an OEM design and correct fit.
comrade904
May 10, 2012 08:58 PM
AlanS
Apr 1, 2011 10:20 AM
JimBee
Sep 28, 2010 02:15 PM
drongo
Oct 29, 2009 12:35 PM
guptash
Jan 31, 2005 04:24 PM
