driver side wiper goes to far
Old Aug 10, 2008 | 07:35 AM
chuckvtvolvo's Avatar
Default driver side wiper goes to far
Had my wiper replaced by the dealer on my 2004 xc70. It now hits the car frame everytime it comes up. I checked the bolt under the cover and it is tight. Any suggestions? The dealer is over an hour away, so I don't want to bring it back. help? thanks!
Old Aug 10, 2008 | 07:45 AM
Default RE: driver side wiper goes to far
Loosen the nut and adjust the position.You will have to push on the arm after loosening the nut to adjust it.
Old Aug 10, 2008 | 07:50 AM
that's kind of what I thought, but wasn't sure. Do I just push on the arm or do I have to pull it off that bolt before I move it?
Old Aug 10, 2008 | 08:14 AM
Loosen nut most of the way. Then push the arm down till you feel it come loose then slide it to where you want it then tighten the nut.
Old Aug 10, 2008 | 08:59 AM
i loosened the nut, but when I push on the arm it won't move, actually both arms move when I push on the driver side, but just slightly and the actual position is not changing. Is it just stuck on there or am I doing something wrong??
Old Aug 10, 2008 | 08:31 PM
The stud is coned shaped. You need to push the arm down towards the windsheild. Not try to rotate it. Once you press it straight down it should come loose.Push by the hinge part.
Dean Rochester
Feb 17, 2014 01:54 AM
Roge
Nov 9, 2007 05:15 PM
charlieruss
Aug 25, 2006 07:46 PM
fast850r
Aug 30, 2005 09:54 PM
