Drivers side low beam headlight dead. 2006 XC90
Old Oct 14, 2015 | 11:30 PM
Perrin's Avatar
Default Drivers side low beam headlight dead. 2006 XC90
So my drivers side headlight died today. Checked the bulb with the passenger side and it lit off no problem. Checked the fuse under hood #16 i I think that was the number. Anyways the one thats labeled for driver side headlight. Fuse was good. Checked power at the fuse and I have 13.8v or so with car running. Checked voltage at the light and its dead. I have continuity on ground. Also checked power to plug ground chassy groung. Nothing. Is there a head light relay somewhere or is it built into the CEM. (Central Electronic Module) I'm kinda stuck atm and dont know where to check next. Im anyone can help me with this id appreciate it. Thanks
Old Oct 15, 2015 | 01:21 AM
doublebug's Avatar
Low beam headlight control is built into CEM. No relay.
Check if there is any errors code that is headlight related (via diagnostics).
If CEM registers errors more than 200 times it switches off power and headlight can be enabled back by clearing errors codes.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
donnacarl
Oct 25, 2014 09:06 AM
marucusu
2001-2013 model year V70
Nov 3, 2012 11:49 AM
ToledoVolvo01
Apr 30, 2010 09:34 PM
