Driving an S70 with no compression in one cylinder
Old Dec 17, 2016 | 11:18 AM
xerxes66's Avatar
Default Driving an S70 with no compression in one cylinder
I want to use a 1998 S70 for a couple of months to drive to work about 50 miles per day. The car has no compression on cylinder #1 but otherwise runs O.K. Is there any chance of ruining the motor driving it that way?
Old Dec 17, 2016 | 12:36 PM
ES6T's Avatar
Yes. But its already ruined. You will likely ruin the cat too.
Old Dec 17, 2016 | 12:39 PM
xerxes66's Avatar
Why will it ruin the cat?
Old Dec 18, 2016 | 11:26 AM
you will be dumping unburnt fuel into the exhaust which will eventually coke up the cells in the cat. Does the car run differently if you disconnect the fuel injector lead for that cylinder? (no compression in one cylinder suggests a burnt valve )
Old Dec 18, 2016 | 02:43 PM
tryingbe's Avatar
Disconnect the wiring to injector #1.
Motor is already ruined. Valve probably broken. Keep an eye on the oil level.
1st time volvo owner
Jul 29, 2010 04:53 PM
mlotek
May 18, 2010 05:48 PM
burnferris
Dec 15, 2008 09:53 AM
jhnmartin
Nov 15, 2008 09:12 AM
ludeless
Nov 14, 2008 06:48 AM
