ETS and engine-light turn-off
Old Oct 30, 2016 | 03:51 AM
BrianLHansen's Avatar
Default ETS and engine-light turn-off
Hi! I have a Volvo V70 from january 2000 (2,4 140HP), and after i put in a new battery recently, the ETS lamp and the engine lamp has turned on. The engine runs as smooth and quiet as ever, so there are no problems, but I can't find a way to turn off those lamps. I would like to do it my self, rather than paying a garage to do it, but can I???
Old Oct 31, 2016 | 11:06 AM
You need access to an OBD2 code scanner to view then clear the stored fault codes. Some shops will do that for free and some auto parts stores will rent out the code readers but that all depends where you are located.
Old Oct 31, 2016 | 03:16 PM
Hi there ! Thank you for responding so quickly. I was hoping for a do it your self solution, but probably need to drop by a local garage to get the faults deleted... Thanks again :-)
jackievolvo
Apr 26, 2012 10:16 PM
mdavies013
Apr 25, 2009 07:38 AM
volvo4lifeson
Mar 5, 2008 08:43 PM
waterkr1
Oct 25, 2007 03:54 PM
