EVAP problems with S70
Old Aug 28, 2013 | 02:56 PM
betsyarant's Avatar
Default EVAP problems with S70
Check engine light came on a few weeks ago, the code says there's something wrong with either the EVAP canister, the purge solenoid, or a vacuum leak. (And yes, I checked the fuel cap.) I did a visual check on the EVAP canister and components, the only thing that looked amiss was a small bubble on the big hose coming out of the canister. Not a hole, but maybe the hose material is thin enough there to cause a leak? Any suggestions? If it's possible that that is the source of the problem, do I need to replace the entire hose?
Thanks!
91shelby
Feb 7, 2022 10:52 AM
fields 100
Sep 3, 2012 09:37 AM
breachandclear
Feb 28, 2011 12:27 AM
whistman
Oct 17, 2010 05:16 PM
m1964
Jun 13, 2006 07:36 PM
