Ghost in the machine HELP !
Old Jul 3, 2019 | 10:05 PM
helmut233's Avatar
Question Ghost in the machine HELP !
Posted in the V90 forum & got no answers **** 1998 V90 wagon *** PLEASE HELP !! ... Wow ! This one is weird ! Starting having troubles with turn signals not working occasionally . Then car would not shift out of park unless transmission over ride in shift boot is pressed . Then the power windows , sunroof & transmission only operate when key is on. When car is started & running nothing works. . Fuses & relays are good . Please HELP !! Point me in the right direction !
Old Jul 5, 2019 | 09:23 PM
gdog's Avatar
Just a guess, but based on your symptoms, I'd suspect the electrical portion of the ignition switch. Not an uncommon failure on this vintage of volvo.
If you jiggle the key when key is in RUN position, and things start working, that would verify it..
Old Jul 6, 2019 | 01:36 PM
helmut233's Avatar
Yes Sir ! Got an email from a guy in PA. yesterday suggesting same thing and that does do the trick to bypass the ghost for now. Going to look into new Ignition Switch...... Thanks !
Old Jul 6, 2019 | 01:49 PM
helmut233's Avatar
Yes that is it Thank You !
helmut233
Jul 6, 2019 02:53 PM
winters-wolves
Mar 15, 2018 01:00 PM
egoldtrap
Sep 4, 2016 01:13 PM
SD96Vol
Aug 9, 2014 10:58 PM
