Key wont enter ignition.
Old Sep 2, 2016 | 11:52 AM
egoldtrap's Avatar
Default Key wont enter ignition.
Hi,
I have a 1992 Volvo 850 and the key will not enter the ignition.
The shift **** is fully popped out and the override is all the way up.
I saw another thread where the user used a sharpened screw driver to open up the entrance to the tumblr, which seems to be the same issue Im having. Just want to double check before I start banging away at the ignition.
Old Sep 2, 2016 | 09:01 PM
egoldtrap's Avatar
I would like to attempt replacing the lock cylinder but there is no way I can do that if I cant even insert the key. Any help is appreciated. If im in the wrong forum please let me know as well.
Old Sep 3, 2016 | 09:27 AM
Psaboic's Avatar
Do you have another key you could try? If not, very carefully try the screwdriver trick to see if you can get the ignition to turn. EIther way it sounds like you are going to be in the market for a new ignition switch
Old Sep 3, 2016 | 11:05 AM
egoldtrap's Avatar
No no other key.
you think the ignition switch is preventing the ignition lock cylinder from opening?
Old Sep 4, 2016 | 01:13 PM
tryingbe's Avatar
I think something is stuck inside of it. Get a flashlight and see.
Patrick
Volvo C30
Dec 1, 2025 10:31 AM
98T5
May 19, 2021 02:44 AM
wjh1540
Sep 18, 2007 05:32 PM
98T5
Aug 15, 2007 05:51 PM
