hard starting
Old Feb 27, 2016 | 05:12 PM
loudog159's Avatar
Default hard starting
almost done putting motor in XCV70 2.4 turbo, new platinum plugs, good coil packs, new fuel injectors, new fuel filter, fresh gas. runs smooth, but has to crank over a lot to start. My crankshaft sensor is not tight, bolt stripped, could that be the cause, or what else should I look at. I cleaned the throttle body before I installed it. thank you.
Old Feb 28, 2016 | 06:23 AM
loudog159's Avatar
also notice when relieve fuel pressure valve on fuel rail, no fuel comes out. could it be pressure regulator or weak fuel pump?
Old Feb 28, 2016 | 11:43 AM
It could be a weak regulator. Have you tried to get a fuel pressure gauge and get a reading ??
Have you checked the vacuum line at the regulator to see if the regulators nipple seeps fuel or the vac hose has a strong smell of fuel indicating a ripped diaphragm in the regulator ??
daver80
Jul 13, 2009 10:19 PM
marclou1969
Sep 27, 2006 08:52 PM
jerryman
May 23, 2006 01:19 AM
Sapient
Apr 10, 2006 10:40 PM
penkogj
Nov 30, 2005 08:07 PM
