help with my mas on my 92 240
Old Nov 6, 2007 | 07:43 PM
chevy1951's Avatar
Default help with my mas on my 92 240
hi everyone i hope you can help, i had replaced my mas on my 92 240 but there is not an change it kept on stalling and running like crap but when i unplugged it the car runs great what else can be causing this problem i'm guessing it's not the mas thanks
Old Nov 6, 2007 | 08:17 PM
tripleb's Avatar
Default RE: help with my mas on my 92 240
You need to reset the fuel system adaptation when you replace the meter. You can pull the fuse or disconnect the battery. Just make sure you have the radio code if you disconnect the battery.
Old Nov 17, 2007 | 12:33 AM
M4yhemz's Avatar
... also check to make sure there isn't any condensation with the fuel system fuse by the ignition coil... here's something you might want to look into buying for your car... cheap and will save you a lot of trouble when you can't figure out why the car won't start... http://ipdusa.com/Volvo-200/Electric...9-257-335-162/
Jabdoney
Jul 27, 2015 07:31 PM
mgreen
Jun 15, 2011 11:48 AM
akabond
Dec 25, 2010 03:05 PM
uenvyboykin
Dec 29, 2008 02:47 AM
HelgaTheS80
Dec 25, 2006 05:46 PM
