codes for MAS and ETM issues
Old Jun 14, 2011 | 09:15 PM
mgreen's Avatar
Default codes for MAS and ETM issues
Does anyone have the codes for a 2000 volvo v70xc for a failure of the MAS or the ETM modules. I am checking the codes to see what is the issue as my ETS light is on and I have very low rpm's.
Old Jun 15, 2011 | 10:18 AM
jda2000's Avatar
The ETS light on indicates that the ETM (electronic Throttle Module) has failed.
A common failure in '99-'02 V70. It's such a common failure(100% failure), that volvo was mandated by the gov to extend the warranty to 10 yrs or 200K miles.
The warranty on your 2000 is over, so its going to cost you. Labor and parts at the dealer will run you close to $1K and it will require software download. Rebuilding your own unit for good thru Xemodex will run you about $600-the best option if you are going to keep the car a few years.
Used units thru the junk yard is a 50 50 proposition, and they might not work at all.
Old Jun 15, 2011 | 11:48 AM
mgreen's Avatar
thanks for the information. I was going to ask abut the Xemodex opton. It looks pretty good right now. Thanks
Jabdoney
Jul 27, 2015 07:31 PM
MarksS60
Dec 1, 2011 12:23 PM
akabond
Dec 25, 2010 03:05 PM
chevy1951
Nov 17, 2007 12:33 AM
HelgaTheS80
Dec 25, 2006 05:46 PM
