install of new rotor
Old Sep 1, 2020 | 03:50 AM
940 nut's Avatar
Unhappy install of new rotor
For some reason, I had first: No problem at all putting on a new left side rear rotor on my '93 940 wagon (T-2.3),
but the other side was well nigh impossible.
I'm diagnosing this as a rust issue, as removing the old one was also quite a dental extraction.
The rim the rotor is to fit over, in order to allow the caliper halves to meet has got a fair dose of rust on it.
In order to make a clean, even sand to remove it, will I:
have to suspend (jack stands plus 2 lifts) both rear wheels, put in reverse, so I can abrade to rust off evenly?
Or is there some other magic I can use (just sand it off as is, not worry about rotating it, because the rotor will be held evenly by the nut attachments to the tire....?
Thanks in advance
Often Befuddled
Jul 19, 2020 02:02 PM
Ben_25
Aug 11, 2016 05:52 PM
JamesFredette
Oct 6, 2008 01:06 PM
danerrr808
Jan 27, 2008 09:08 PM
MJAlex
Sep 24, 2007 06:25 PM
