Rear rotor removal
Old Sep 29, 2008 | 08:37 PM
JamesFredette's Avatar
Default Rear rotor removal
trying to replace the rear rotors on my 96 850, Ive got bolt that holds the rotor in off, along with the caliper. I can't figure out what is holding the rotor on. my theory is that the ebrake is somehow holding it on. When i tried to adjust the ebrake manually from inside nothing really happened. Please get back to me asap. TIA
-James
Old Sep 29, 2008 | 09:14 PM
Ozark Lee's Avatar
Default RE: Rear rotor removal
You need to back the star adjuster off so as to get the parking brake shoes past the "rust ring" on the inside lip of the drum part of the shoe. It is a bearcat to actually find the star adjuster through the hole in the face of the rotor. This might help:
I did a writeup on rear brakes here that has some other tidbits:
http://www.matthewsvolvosite.com/cha...?p=26225#26225
...Lee
Old Oct 1, 2008 | 11:16 PM
thank you very much lee. i appreciate your time
Old Oct 2, 2008 | 08:29 AM
Psaboic's Avatar
You might try lightly tapping the rotor with a rubber mallet too. Sometimes they get some corrosion that makes them stick to the hub
Old Oct 2, 2008 | 02:32 PM
wheelsup's Avatar
Mine were rusted on like no tomorrow. I don't think they had been touched in 7-8 years, and the car was in NH the whole time. I hit it over and over and over and finally they came off after a good 5 mins of wacking. It had nothing to do with the parking brake in my case. Put some anti seize on the hub when you put the new ones on if you want them to come off easily next time.
Old Oct 2, 2008 | 08:32 PM
bitter356's Avatar
I might be out of line here but... Hit that son-of-a-b***ch on both sides! enjoy!!!
Old Oct 5, 2008 | 09:44 AM
MikeySq's Avatar
volvo is smarter then the averager automaker, the little star spinney thing you have to adjust to loosen the Ebrake shoes to remove your rotor is made of aluminum and not steel like some other auomakers so you shuld be able to free it and remove the rotor. I've seen some others tgat are made with steel and they sieze together and hey make remoal(loosening) impossible!
Good Luck!
Old Oct 6, 2008 | 01:00 PM
So im stuck again. Any pictures/diys on how to remove the brake pads on the rear. I cant seem to get the pins holding them in out.
Old Oct 6, 2008 | 01:06 PM
Ozark Lee's Avatar
The pinsjust tap out from the outside caliper. A punch makes it a little easier but I have used a nail before.
...Lee
sterling
Dec 6, 2011 04:55 PM
rolling2
Oct 20, 2010 01:08 AM
fishingboy
Nov 10, 2008 09:11 AM
bigblock
Feb 7, 2008 08:50 PM
go2sharks
Jun 8, 2007 06:12 PM
