intermittent missfire cyl 5
Old Apr 19, 2010 | 09:32 PM
lj320's Avatar
Default intermittent missfire cyl 5
I have a 1996 960 189000 miles. This car has a intermittent missfire. sometimes at idle or any speed even 75 mph. then missfire gos away
and car runs fine. check eng lite comes on code shows missfire cly 5.
volvo dealer changed coil said car ck out ok. I get in drove a block
and missfire, ck eng lite on, code #5 cyl. ANY ONE HAVE SAME PROBLEM
or IDEA....
Old Apr 19, 2010 | 11:14 PM
gdog's Avatar
Dumb question but did they replace the spark plug(s) while they were at it?
Old Apr 20, 2010 | 06:16 AM
lj320's Avatar
yes new plugs are installed...
Old Apr 20, 2010 | 09:37 AM
modelageek's Avatar
throw a large bottle of techron in the tank...... do these have cops or wires?
Old Apr 20, 2010 | 01:34 PM
lj320's Avatar
960 has coils and yes I have swap coils around to chec if it was a bad coil... No help... still get missfire #5 cyl code...
Old Apr 20, 2010 | 02:09 PM
modelageek's Avatar
I would put the techron in.......what do you think about a faulty injector? can you get a hold of a scanner?.......do these thing have ignition modules or are they run thru the pcm? never hurts to do a compression test eventually if you can?
Nirky
Jul 29, 2010 02:21 AM
850_Volvo_Dan
Jun 17, 2010 01:47 PM
andrei3333
Mar 12, 2010 10:14 PM
andyr
Jul 19, 2007 07:02 PM
kennys s40
Oct 23, 2006 10:22 PM
