Missfire on Cyl #6 at WOT only
Old Mar 11, 2010 | 05:46 PM
andrei3333's Avatar
Default Missfire on Cyl #6 at WOT only
so this happens at really hard acceleration when the revs go to the max at different speeds
the code sets as P0306 missfire on cylinder #6, i reset the code, i can replicate these conditions at will, but at normal driving ( when not going nuts on her ) this never happens
all the maintenance is done, new plugs and all, 4 of 6 coils have been replaced EXCEPT #5, and #6
could this be a coil slowly going bad or a bad injector ?
i usually drive normally and try to conserve gas and not beat on her, but when i really need to get out of a jam and floor it this happens, its kinda annoying, she runs fine and quiet with perfectly steady rpms at idle...gas mileage is normal for this car and very consistent for the year and a half that i owned here
any thoughts ?
Old Mar 11, 2010 | 09:11 PM
I would say the coil is going out.
Old Mar 12, 2010 | 07:39 AM
NoLifeTilBoost's Avatar
Swap coils #2 and #6, if the misfire code moves to cyl #2, then you have your answer
Old Mar 12, 2010 | 08:12 AM
andrei3333's Avatar
yeah im kidna too lazy to take the turbo hoses off though lol, ill try on the weekend, i may just drive until the coil fails completely
Old Mar 12, 2010 | 09:17 AM
Consider this though, if it starts to misfire regularly under normal use, aside from the nasty-*** vibrations you can possibly wipe out a cat and O2 sensors from the unburnt fuel.....Now thats going to be some work.
Old Mar 12, 2010 | 07:30 PM
+1 to that!
Old Mar 12, 2010 | 10:14 PM
andrei3333's Avatar
ok fine i might as well just buy a coil online its like 50 canadian plus shipping for 11 dollars
thanks for the help guys...
lj320
Apr 20, 2010 02:09 PM
kyvahe
Jun 25, 2009 08:04 PM
Cobra_03
Jan 31, 2009 10:04 AM
hispeed
Apr 9, 2008 05:31 PM
