Stuck servicing PCV - Need help removing fuel lines
Old Nov 6, 2008 | 08:17 AM
axelm's Avatar
Default Stuck servicing PCV - Need help removing fuel lines
I finally have some time to service the PCV. I am using this write up: http://www.lakesidedp.com/uploadpics/pcv/
I am on step 6b, but I can´t remove the fuel lines. It´s very hard. Do I have to cut the line and replace it?
Help! I am stuck.
Thanks
Axel
Old Nov 6, 2008 | 08:26 AM
Default RE: Stuck servicing PCV - Need help removing fuel lines
Remove the clamps on one side of the rubber hose.
You cannot get the line loose on the pressure line?
The nut will not loosen?
If all else fails pull up on the fuel rail and remove the T-25 screw on the end and slide the connection out of the end of the fuel rail.
Old Nov 6, 2008 | 08:35 AM
axelm's Avatar
The rubber hose part is easy.
The problem is with the other line. It has a 14 nut that is terribly tight.
Regarding pulling on the rail, should I take any special precautions?
Old Nov 6, 2008 | 09:21 AM
axelm's Avatar
How am I supposed to remove this? Do I have to turn counter clockwise on the top nut while I hold the bottom nut in place?
[IMG]local://upfiles/4713/14FF7B6D11A94006B75CB223CB8B0CCA.jpg[/IMG]
Old Nov 6, 2008 | 10:19 AM
axelm's Avatar
BUMP for Tech.
Old Nov 6, 2008 | 12:17 PM
axelm's Avatar
I pulled the whole rail. I was afraid of breaking the lines. Now I am trying to remove the manifold bolt beside the dipstick.
Old Nov 6, 2008 | 03:55 PM
Ozark Lee's Avatar
I would be inclined to buy new O-rings and caps for the injectors before you put them back in. I had no problem with the fuel lines on the three PCV services I have done.
Old Nov 6, 2008 | 04:31 PM
Once the rail is loose on the end is a little plate that holds the fitting into the fuel rail.
As long as fuel pressure is empty all will be fine.
Aug 7, 2013 10:28 PM
mylesfalconer
Aug 20, 2008 12:40 AM
reillys70
Sep 9, 2006 05:24 PM
cisco78
Jul 26, 2006 08:43 PM
S70turbo1999
Jul 9, 2006 10:51 AM
