Need help Volvo s40 -01
Old Oct 23, 2015 | 09:38 PM
Herjan's Avatar
Default Need help Volvo s40 -01
I need your help!!!
Have a Volvo s40 2001 1,9t 140k and having issues.
Had it for almost 2 years.
Starting to get issues after 4 month trouble starting after driving and trying to restart after standing for 10-60+ minutes. It starts when cold..then driving for 30-90 min. Stops and then trying to start it after a break. Can't get it to turn over. Battery good..tried starting gas in the air intake. Changed fuel pressure reg...worked! 3 month later same thing started all over again. First week it starts with me pushing down the gas. Mechanic changed vacuum pump..starts again. 3-4 month later...same thing. Changed chrankshaft sensor after a mechanic said that was wrong...worked for 2 days. Drove for 1,5h,..stops and try to restart after 20 min. Doesn't start. Spray start gas..gets it barely start after working gas pedal for 10 sec. New mechanic...says spark plugs are all fouled out..change it. Pressure test all..says engine is good. Drives home 1,5 h...goes out to test start after 1 h...same problem. I'm so frustrated and desperate!! I need help!
Used 91 octane...gramma driven by me.
Coil pack was not issue according to last mechanic.
So basically starts cold...after dr one for a while and then standing for 10 min plus...no start. Starter works..brand new spark plugs.
Sea level and 6k ft Colorado.
Help me
ryanturbos40
Nov 24, 2014 06:28 PM
umdterps
Oct 9, 2011 04:03 PM
Sanel30
Feb 18, 2010 09:16 PM
chef
May 19, 2009 05:57 AM
lamb2k
Feb 22, 2009 08:08 PM
