o2 sensor wiring?
Old Nov 1, 2008 | 01:51 PM
jwardmls's Avatar
Default o2 sensor wiring?
hi, i have an o2 sensor code. i think its loose wiring, but im not sure where the sensors are located on my 02 s80 t6. also there is some kind of groaning sound coming from the engine area on deceleration from around 4k rpms, and i dont kno if this could be because of the upper mount being practically non existant, or if it might be something in the trans... any help, as always, is appreciated.
Old Nov 1, 2008 | 01:52 PM
jwardmls's Avatar
Default RE: o2 sensor wiring?
sorry i meant 2001 s80 t6... i just traded an 02 s40 for it, i guess i had it on my mind....
Old Nov 1, 2008 | 08:36 PM
I would say the sensor is bad. There usually isn't wiring trouble with the sensors.
I would replace the mount on the noise and see if that fixes it.
Your car has 4 O2 sensors total.
Old Nov 2, 2008 | 02:50 AM
jwardmls's Avatar
how do you kno which one is bad and needs replacing? the car runs really strong and has no trouble shifting in automatic or man so im not real worried about the trans or engine... it has 117k on the odometer, so i imagine it still has plenty of life left to live. the mount is only $70 at carquest. and the o2 sensors run from $80 to $180. so no biggie... thanks again.
Old Nov 2, 2008 | 06:09 AM
The O2 codes should tell you which one you need Bank 1 or Bank 2 front or rear.
Old Nov 2, 2008 | 01:54 PM
jwardmls's Avatar
the reader at the parts store just brought up o2 sensor... didnt specify which one. does it have to be a dealer tool to pull the proper code?
Old Nov 2, 2008 | 06:16 PM
It has to be a decent scanner that reads the system correctly.
Old Nov 3, 2008 | 09:34 AM
jwardmls's Avatar
cool beans... thanks tech. ill keep u informed on the issue...
Boostwhat
Feb 23, 2018 03:39 PM
sdl92
Jun 22, 2013 07:19 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
dwhartwell
Jan 20, 2008 10:59 AM
