Oil change/filter question
what year/engine?
The big o-ring is for the filter housing that fits into a slot and the small one is for the oil filter cap plug. You should also use a fresh crush washer (usually copper or aluminum) for the drain plug but typically those are sold separately
It is a 2018 XC 90 T6 R-Design
the filter comes with two O-rings pre installed. So this leads me to believe this small washer is for the silver drain plug on the bottom of the filter housing.
I noticed in another post that they said it is for the check valve inside the filter housing.
HummerGuy
10-12-2008 11:39 AM
