Oil change problems, need help...
Old Oct 24, 2009 | 07:49 AM
Sanel30's Avatar
Default Oil change problems, need help...
Went to the oil change place, took my own filter as I don't trust the generic brand there.
While I saw the guy put in new synthetic oil I counted the bottles he was putting in from behind the safety glass. After the 6th quart I saw him open another one. I thought its ok since my '01 V70 T5 takes 6.1 quarts.
I was amazed to see him drain the 7th ****ing quart in the engine. And convincingly both he and the management said "nooo its 7 quarts, don't worry you're ok" and I know I'm right.
What do I do now?
Drain the whole thing and put new oil in as I know I won't be able to take out the proper amount by taking the plug out and putting it back in at the right time.
How do I go about this?
Old Oct 24, 2009 | 04:15 PM
blackbrick's Avatar
Check oil level first, if it is above max do not drive
When car is cold take the tplug out and drain some oil out. After putting plug back check level using dipstick and add more oil if needed. You can use same oil since it is new. Have some towels handy. Difference from min to max on the dipstick is about 1 quart
Old Oct 24, 2009 | 06:03 PM
Typhoon's Avatar
Taking the oil filter off and draining that is usually good for about 500mls of oil.
Regards, Andrew.
gkinser
Oct 6, 2019 07:35 PM
Alex_Daniel
Mar 26, 2013 01:01 PM
rusvolvo
Nov 24, 2011 02:18 PM
ajahn
Sep 4, 2010 08:54 PM
Miatamon
Jan 26, 2007 04:34 AM
