Need to change fluids, need some great advices, thanks
Old Nov 21, 2011 | 10:54 PM
rusvolvo's Avatar
Default Need to change fluids, need some great advices, thanks
Hello all, I do have 2004 S60r, 105k miles, manual, i need to replace fluids.
will you guys tell me what would you recomend for oils:
Engine oil and filter
Manual transmission oil
Rear diff oil
Bevel Gear and Angle gear oils
power wheel fluid
Those are the most fluids i want to change asap, primary i am going to drive that car in winter, so what oils your will reccomend, brand and weight please. thank you
and in case you know any great volvo web sites that do sell all i need, let me know please, many thanks
Old Nov 22, 2011 | 09:58 AM
jbuck's Avatar
Well i have to admit being an Amsoil dealer i am partial to Amsoil but here is the link for the products that are recommend for your vehicle. You can PM me if you have any questions
2004 VOLVO S60R 2.5L 5-cyl Engine Code [52] B5254T4 Turbo - AMSOIL Online Product Application Guide
Old Nov 22, 2011 | 10:46 AM
lx302's Avatar
I would think your owners manual, if you have one, will have the factory recommendations. Did you check there first? I assume your looking for personal recommendations and good experiences?
Old Nov 22, 2011 | 03:16 PM
rusvolvo's Avatar
thank you, i do not know if i need to go with castrol, mobil, motul, or mobil 1, its so many choices
Old Nov 23, 2011 | 11:46 AM
Johnny Volvo's Avatar
Castrol Synthetic "Edge" for engine
Toyota T-IV for Trans. (Cheapest at the dealr. $5 per quart.)
Follow directions on the "Transmission Fluid" sticky.
Old Nov 24, 2011 | 07:28 AM
RGT's Avatar
RGT
I got my power steering fluid from Volvo, I could not find a spec for it to allow me to buy it elsewhere. I did find there was a lot of sediment in the reservoir so it is worthwhile to clean that while you are doing it as there is no filter in the system.
Old Nov 24, 2011 | 09:12 AM
You need to do what your maunal recommends. If you do not have a manual, use the one that Volvo put on line for you. Go to Volvo Information | Owners & Enthusiasts Click the owners manual link.
There is also a link there for you to register your car with Volvo in case you are not the original owner and have not had any warranty work completed. You should do that because they will notify you of any recalls and other things that you may need to know. They DO NOT send you junk mail.
I also join their High Mileage Club. They usually send you a sticker, letter, and coupons to get discounts on parts etc.
Also check your manual for fluid service intervals. Some fluid may never need replaced like power steering fluid. Draining that may cause damage. Try to remember that it can be just as important servicing the car going into summer as it is into winter.
The main fluids that you should be concerned with changing are:
- Motor oil and filter.
- Coolant
- Brake fluid.
- Transmission fluid
Fluids that should be monitored for level:
- Steering fluid
- Windshield fluid
Make sure you're timing belt and breather system has been serviced/replaced.
Old Nov 24, 2011 | 02:18 PM
rusvolvo's Avatar
- Coolant
- Brake fluid.
- Steering fluid
- Windshield fluid
thank you so much, i will follow your recomendations
innerpeace
Apr 24, 2015 01:15 AM
Lansdowne
Sep 22, 2014 01:02 AM
volvohot
Jan 3, 2008 08:56 AM
Siento
Oct 29, 2006 02:39 AM
