RADIO Question
Old Jan 23, 2008 | 07:59 PM
NadineInTexas's Avatar
Default RADIO Question
My raidio plays but has no display anymore...I tried turning it off and counting to ten but I turned it back on and it lights up but no display..works fine..looks great..as long asI do not wonder what stationI am listening to..
2004 V70R Wagon
Old Jan 23, 2008 | 10:20 PM
ikes4ever's Avatar
Default RE: RADIO Question
well I would perform a swedish reboot by disconnecting the battery for about 5 mins very common procedure on saabs when this happens to them. not sure on volvo thou may cause more harm then good.
good luck
Old Jan 24, 2008 | 05:58 AM
Thank You! Well the nearest dealership is 3 hours away..soI might just live with no display....I am scared to disconnect anything.
Old Jan 24, 2008 | 08:11 AM
jks2's Avatar
Don't disconnect the radio unless you have the anti theft code. It is a 4 digit number. If you don't have the code in your possession then when you unhook the radio you wont be able to use it til you input the code. You can also get the code from the dealer if you give them the VIN.
Old Jan 25, 2008 | 06:15 AM
I did nothing and It works now...weird huh? Well I can live with that.
Old Jan 25, 2008 | 10:04 AM
jks2's Avatar
Wow! You're good, using telepathy to fix your radio.
Old Jan 25, 2008 | 06:34 PM
I was going to kick it...But my husband advised against that...~LOL~
cbgav
Sep 10, 2007 05:25 PM
aaronw_1986
Aug 30, 2006 01:12 AM
Riculus
Dec 5, 2005 09:37 AM
