Rear Control Arm Leakage 2003 Volvo S80
Old Mar 18, 2017 | 12:54 PM
Skyharbor12209's Avatar
Default Rear Control Arm Leakage 2003 Volvo S80
I have a 2003 Volvo S80 Non Turbo and I have been seeing some oil leakage coming from the area to the right of the driver side rear tire. Today, I managed to crawl up under the left rear of the car and can see what I would call "leakage" of oil from a bushing that is attached to what I will call a "control arm?"
Question, is there oil in this "control arm" and does it mean the bushing only needs replacement or the entire lower control arm? It is only leaking on the left (driver) side, the right side (passenger) looks dry. Is this in fact some sort of control arm?
Old Mar 19, 2017 | 12:08 PM
Corey Conklin's Avatar
can you throw me the VIN? I will look it up for you.
Old Mar 19, 2017 | 03:37 PM
Default 2003 Volvo S80
VIN : YV1TS92DX31314100
Thanks.
G
Old Mar 21, 2017 | 11:51 AM
Thanks.
G
I took a look and nowhere on this end did I see where oil should be...
now if it is coming from a bushing it could be grease in the bushing and if it's leaking it may be overfull, going bad, or bad already...
if you were to post a picture of exactly that part I could get more specific but from what you described it sounds like it shouldn't have oil in it.
Old Mar 22, 2017 | 08:33 AM
Default Volvo S80 Rear Control Arm Oil Leakage
Okay I will try and get back under there and take a pic. I do think it is a bladder type thing where grease may be leaking. I don't see a Zerk fitting there.
cheewooi
Jan 20, 2012 12:32 PM
Platinum52
Jul 17, 2009 07:33 PM
s80lady
Sep 3, 2008 08:21 PM
loopcharged
Mar 26, 2008 04:19 AM
03v70
Jan 18, 2008 08:32 PM
