rear power window just stoped working
Old Feb 28, 2018 | 12:25 PM
angelscorpio38's Avatar
Default rear power window just stoped working
Hello
I recently just had an stereo put in by quality auto sound and a day later notice that both my back rear power windows are not working but both the front ones work fine i have 2004 volvo xc90 do you think they could have blown a fuse or something ???
Old Feb 28, 2018 | 05:14 PM
donf's Avatar
They COULD have done anything. Or nothing. Since you suspect a fuse I am wondering if you have checked this possibility yourself.
Left side of the dash, open drivers door. # 7 controls both back doors - as well as the Child Safety Locks. If those aren't working either then you most likely have diagnosed the problem.
It's a 30 A fuse and you should have a spare in the box. It's possible that something happened during the install and, if it was momentary, then a new fuse should fix it up without a return trip to the audio shop. Otherwise they my have left something shorting, that of course will simply keep blowing the fuse so is an easy observation to make and you will want to return to have them donate their labor. Unless they were placing speakers in the doors I can't see a short there. Did the wire it into the fuse panel? lot of wires to mess with there.
Old Mar 1, 2018 | 01:49 PM
Default It was the fuse
Thanks a bunch
FATHAMSTER
Sep 1, 2013 11:03 AM
steve2812
Jun 8, 2013 10:39 AM
AZvolvoMan
Mar 15, 2013 01:06 PM
Filomenod
Jun 22, 2010 08:58 PM
s70gltkid
Feb 17, 2008 10:37 PM
