sun roof stoped working
Old Jun 8, 2013 | 10:24 AM
steve2812's Avatar
Default sun roof stoped working
hi all my suroof stopped working i removed the alarm fuse it had blew changed it sunroof worked then the fuse blew again put another one in now nothing any one have any ideas why also if you can help my back door will not open from inside or out side still locks but wont open any help would me much appreciated
Old Jun 8, 2013 | 10:34 AM
Hi, 1 problem per thread will do you better.
I would pull the switch for the sunroof, change the fuse, and see if other things work. Is the sunroof the only thing that is not working on that fuse? If so, you likely have a short in the motor and will have to replace it.
Old Jun 8, 2013 | 10:39 AM
As for your back door, you will have to pull the lower back seat cushion, pull the door panel, then bump a red lever on the latch to get it to pop open. That happened to my daughters S70 once when she was unlocking to door for someone and they pull the handle at the same time. After I cleared the jam it worked fine.
aoneal2000
Aug 16, 2020 06:49 AM
AZvolvoMan
Mar 15, 2013 01:06 PM
Filomenod
Jun 22, 2010 08:58 PM
850forum
Sep 30, 2008 05:43 PM
armstrong_b09
Dec 29, 2007 12:09 PM
