Rear Washer Fault 940 estate
Old Jan 2, 2011 | 05:12 AM
brixton_tom's Avatar
Default Rear Washer Fault 940 estate
Probably due to sudden seasonal overuse my rear washer has stopped working. By coincidence I had a washer reservoir fault which I fixed by washing the gunky filter. The front and headlight wiper jets work perfectly but sadly the rear jet still not firing out fluid, I can hear the motor wine, I can see that no fluid is getting to the jet as inspected the hose connection underneath the tail gate. I can see various rubber hoses coming out of the reservoir but I am not keen on pulling them apart for fun as I have no idea where they go. Cheers
Old Jan 3, 2011 | 12:01 AM
Typhoon's Avatar
More often than not, the actual squirter fills with junk. It took me ages to get the rear squirter clean on my car. Pop the hose off at any convenient fitting and see if water comes out when you operate the switch. If it does, you have found your problem. If not, work your way forwards.
Generally, if the washer motor pumps, it is a blockage at the actual squirter, but in rare cases it can be a crimped or kinked line.
If you do find the hose blocked, compressed air forced towards the reservoir can clear a blockage, you won't damage the pump as it's not a positive displacement pump.
Regards, Andrew.
Old Jan 7, 2011 | 02:37 PM
ibanez958's Avatar
possible leaking somewhere, check the rear headliner if it is wet
Old Jan 22, 2011 | 10:02 AM
Hi Typhon, no luck. When I opened up the rear door and popped off the hose (by the hinge) from the metal hose it was dry, I forced some compressed air into it and tried the pump, again I could here the motor whine but still no fluid. I assume these is no way to access the hose as it must run inside the bodywork all the way into the engine compartment? Is there a diagram of what the various hoses do and where they go? Cheers
Old Jan 25, 2011 | 02:44 AM
Typhoon's Avatar
Start at the other end. The rear washer motor is on teh side of the pump reservoir under the air box. I forget which one it is.
Regards, Andrew.
Old Jan 26, 2011 | 01:45 PM
Thanks Andrew, I assume I have to remove the air box? Is that a tricky job? Tom
Old Jan 28, 2011 | 05:54 AM
Typhoon's Avatar
Not too tricky, you do have to remove a few intake hoses and wires from the airbox, but patience and about a half hour should get you to the washer reservoir. There's really nothing to reassemble incorrectly either, it's all fairly obvious.
Regards, Andrew.
v1lcins
May 20, 2022 10:53 AM
Dobbersky
Apr 17, 2008 09:51 PM
dickwroe
Mar 27, 2006 09:41 PM
harbour
Jul 26, 2005 06:09 PM
VolvoAmateur
Sep 11, 2004 04:59 AM
