Oil Leak from 940 Estate (station wagon)
Old Apr 17, 2008 | 07:11 AM
Dobbersky's Avatar
Default Oil Leak from 940 Estate (station wagon)
Hi I'm new to this post and I'm english so some of the vehicle terms are a bit different to me. I've searched all 123 pages and can't find the same query as mine.
I have a 95 940 2.0 non turbo and it has an oil leak form the engine. I don't know where it is coming from and I'm stuck. I've replaced the Rocker Cover (top of engine) gasket but this hasn't solved the issue. Please help as oil is getting on the exhaust manifold and smoke bellows from the bonnet (hood) most of the time
Thanks for your help and guidance
Dobbersky
Old Apr 17, 2008 | 09:51 PM
jonesg's Avatar
Default RE: Oil Leak from 940 Estate (station wagon)
I'm English, living in America, I'll translate.
Most of them leak oil, its thought of as typical due to the alum head on an iron block.
Mone leaks but not enough to smoke. (ye
t)
If you're loosing a lot oil and its becoming a problem you're due for a head gasket, its not a big job, its made simple because theres no timing chain to deal with, just a rubber timing belt.
Some brickblard posts
http://www.brickboard.com/FIND/searc...p;ul=%2FRWD%2F
And the FAQ file, diagnosis
http://www.brickboard.com/FAQ/700-90...gasket_Failure
more replacement tips
http://www.brickboard.com/FAQ/700-90...eplacementTips
Mustsail
2001-2013 model year V70
May 10, 2014 02:44 PM
saraseaside
1998-2000 model year V70
May 17, 2013 10:46 PM
avalynx
Nov 24, 2011 05:40 PM
96850urbo
Mar 3, 2009 12:35 AM
Qamar
Oct 31, 2005 04:37 AM
