Relay works but aint gettin no currrent to my injectors
Old Oct 12, 2010 | 04:22 PM
scorpius's Avatar
Default Relay works but aint gettin no currrent to my injectors
I have a 91 740 GLT... thought I had a Relay problem but that was not the problem, both units click when I set the key on 2...anyhow, I read up on the problem alittle and found that one part of the Relay sends a signal to the fuel pump while the other sends a signal to the injectors... I get nothing when I turn the key, just the dash lights turn on....I hear the Relay click but nothing, I checked the wiring in the engine compartment and I had Oxidation at every terminal... well I spent the day cleaning up the passenger side harness connectors...thinking I had a connection problem, its the end of the day and I still got no nothing... could it be the Computer? it has a new coil, new sparkplugs n wires, new starter, battery gives me 12.64 volts...dont know what else to do...please help me out if you can..
Old Oct 13, 2010 | 07:33 AM
patsfn2's Avatar
check your fuse for your fuel pump to make sure that the fuse has not blown, however it you hear a relay clicking that could be the sign that the relay is bad...that could be one of the issues...not saying it is but it is a good place to start! post your findings....with everyone here on this site I am sure that we can help solve your problem! good luck
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
kevbrown
Apr 25, 2012 03:49 PM
scorpius
Apr 20, 2011 02:19 PM
skipv
Mar 2, 2011 10:39 PM
Torkk
Dec 13, 2007 06:02 PM
