bet you aint seen this?
Old Apr 22, 2012 | 03:57 PM
kevbrown's Avatar
Question bet you aint seen this?
hi guys, im new to all this but seems like a lot of you know a lot of things about volvos so i home maybe some of you may know whats going on with my car
first of all i have a s60 d5 on a 2003 plate with 61000 miles. i bought it and its a pain to start in cold weather, even today 11 degrees and its difficult. i first thought heater plugs then someone mentioned injectors. i got my mate to come have a look and he brought the "leekoff/back" thing, a clear box with tubes that connect to the injectors, looka a bit like an octopus we tried to start the car but it was having none of it. the ooctupus thing was connected and the first injectors tube filled with fuel and a few of the others had little bits of fuel. so my friend thought no 1 injector was broke. he had a word with a few people and they seemed to agree. he came bact a few days later and we managed to get the car started. i have an obd 2 cable and plugged it in and a few fault codes came up
P0244 turbo wastegate solinoid 1 peformance
P0273 cylinder 5 injector circut low
THIS IS WHERE IT GETS INTERESTING
i googled cylinder 5 injector circut low and it mentioned fuel filter. so hoping it wasnt injectors (expensive) we have a look for the fuel filter. the fuel filter was not their, it was bypassed with what i think is a pump, lookes like a pump, rugby ball shaped and rubber. i think whoever owned the car before me may have had a ding and done that rather than having it sorted properly.
when the car runs it runs smooth and no problems. its just getting it started. what i think is the problem is the fuel is returning the the tank so when i try to start it the fuel has to come all the way through from the tank to engine. the car will start no problems if i get it running and the turn it off and try again.
can anyone help with this? its all rather strange
many thanks in advance guys
this is whats on onstead of the filter
Attached Thumbnails bet you aint seen this?-peugeot-bulb-type-rubber-hand-primer.jpg
Old Apr 25, 2012 | 03:49 PM
jks2's Avatar
Looks like what is on the back of my boat which I use to hand prime the engine when it hasn't been started in awhile.
skipv
Mar 2, 2011 10:39 PM
scorpius
Oct 13, 2010 07:33 AM
s40glider
Apr 4, 2009 12:20 AM
dadto5
May 8, 2008 03:46 PM
Torkk
Dec 13, 2007 06:02 PM
