timing belt broke
Old Jan 9, 2008 | 10:03 PM
vances70's Avatar
Default timing belt broke
i just bought a 1998 S70 volvo and the previous owner said the timing belt broke and everything as far as the camshafts are out of wack. i am trying to re align the pulleys to replace the timing belt but can find a procedure if anyone can help with a worded explanation or pics it will be appreceiated thank you
Old Jan 9, 2008 | 10:33 PM
ikes4ever's Avatar
Default RE: timing belt broke
if the belt broke you may need a new head. most likely the valves bent.
Old Jan 10, 2008 | 07:01 PM
Rickc10ny's Avatar
You should have stopped here first
Old Jan 11, 2008 | 07:42 AM
shelbylay's Avatar
Ya, your valves prolly bent. I have a 98 S90 and my pulley tensioner came off and messed everything up and bent all 24 of my valves. I had to get the head rebuilt, it isnt cheap
Old Jan 11, 2008 | 09:44 AM
JimKW's Avatar
Did the seller inform you that it will need a new engine? If not, tell him you want your money back. If you don't get it back, threaten to sue him. Or ifyou are ok with what you spent on the car in that condition keep it and have it fixed. Probably in the ballpark of $2,000 to $3,500 depening on what approach you take. Any time the timing belt breaks on an interference type engine it messes up the valves which messes up the head.
Old Jan 11, 2008 | 09:52 AM
JPN's Avatar
JPN
And sometimes the piston tops get damaged from hitting the valves as well....
JPN
Old Jan 11, 2008 | 10:41 AM
jks2's Avatar
Which could also mess up the cylinder walls which would require either boring and putting in oversize pistions or boring and sleeving the block. Anyway you look at this situation it is not going to be pretty. The only question is how ugly will it get.
Old Jan 11, 2008 | 05:29 PM
Eric J's Avatar
Welcome to the Forum Vance.
Are you still breathing?
Old Jan 11, 2008 | 07:21 PM
You need a new Head or all the Valves replaced.
Old Jan 12, 2008 | 08:13 AM
JimKW's Avatar
Tech is referring to the cylinder head on the car, not the one on your shoulders.
Old Jan 13, 2008 | 03:46 AM
Typhoon's Avatar
ORIGINAL: JimKW
I dunno, read this:
ORIGINAL: tech
Maybe he means, after reading this post his head has exploded,or he's ruptured all the arteries to his heart.[:-]
Regards, Andrew.
akem21
May 9, 2010 11:44 AM
darimik
Jun 28, 2009 07:32 AM
pos960
May 2, 2007 12:57 AM
Verum
Jul 4, 2006 04:55 PM
carol
Mar 6, 2006 09:53 PM
