volvo engine 2.4t pressure HELP!
Old Mar 5, 2009 | 05:40 PM
Hambo's Avatar
Default volvo engine 2.4t pressure HELP!
my volvo engine has to much pressure its leaking oil for all the seals just changed the pcv Help
Old Mar 5, 2009 | 06:55 PM
malaka's Avatar
The PCV is the likely bad part. Especially if this developed immediately after you changed the PCV. Are you sure its pointing the right way? Did you save the old one? If so, put it back in and see if the problem is solved. If so, then your new part is bad -- stuck in the closed position (if its put in right, that is).
The odds of it being another problem are slim. Possible, but slim. Crankcase pressure is building up and can't go into the intake which is what the PCV does.
Years ago, (like 1965 and before) cars vented into the atmosphere, usually through the oil filler cap. Not now.
Make sure your PCV is put in properly; and if so, change it out for a known good one.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
MntnDewMan
Apr 3, 2024 04:05 PM
brettboze
Mar 26, 2012 06:25 PM
jmotrain
Apr 8, 2011 10:24 PM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
