What liquids do I put where?
Old Nov 25, 2013 | 09:46 PM
Vintage's Avatar
Default What liquids do I put where?
Hi,
I have a 1982 Volvo GLT.
The problem is that there are two cylinders that require some sort of fluid and I don't know what goes into them.
I have attached a photo. I am pretty sure that the white one (green circle around it on the photo) holds brake fluid?
The other one (yellow circle in the photo) I don't know at all.
The online manual for my car sort of shows some photos and information but I don't understand it 1982 Volvo DL, GL and GLT
I am just not car savvy at all. Is there special fluids that I have to purchase for my car model? The white container (green circle in photo) has an inscriiption, "dot 4 fluid from a sealed container". What does that mean?
Old Nov 26, 2013 | 02:18 PM
ES6T's Avatar
The green circle is the brake reservoir and the yellow circle is power steering.
DOT 4 is just a specification level for the brake fluid. However, you shouldn't need to top it off. The level drops as the pads wear so if it is low, have the brake pads checked and replaced if needed. It does look dirty, so having it flushed would be a good idea as well
jsenge
Jan 30, 2007 09:30 PM
xmoke
Jan 21, 2006 07:38 PM
dnphipps
Apr 20, 2005 10:27 PM
halekai
Oct 25, 2004 10:28 PM
szs40
Sep 16, 2004 11:53 PM
