winter/wet driving mode
Old Oct 10, 2012 | 03:23 AM
JKas's Avatar
Default winter/wet driving mode
i am a new owner of a 2006 v70 turbo , the owners manual is not clear about the "W" driving mode--is it only to be used for starting to drive or once you switch to that mode can you leave it there and continue driving on the highway
Old Oct 12, 2012 | 09:06 AM
donf's Avatar
It just starts you out in a high gear (3rd) so that you don't spin your tires on ice/snow. You can leave it there w/o damage. Unless you are on very slippery roads it is very irritating to feel like you are towing the Queen Mary every time you pull away from a stop.
Old Oct 12, 2012 | 10:13 AM
turboglt's Avatar
i found that in winter mode D=3rd and 4th gears
3= 2nd gear and 1= 1st gear... it basicly lets you choose your gear manualy
Old Nov 27, 2014 | 09:46 AM
tom umholtz sr's Avatar
Default keep it in Winter mode?
Would it cause any mechanical problem if I kept it in Winter mode? My 2001 C 70 is very new to me. I am learning as I go. I love the acceleration but my wife is not comfortable with it at all. To me, the Winter mode seems like the engine is not working hard at all. Reminds me of Chrysler's Fluid Drive in the 1940's. There were four speeds but you rarely used the two lowest. I don't think my mother ever realized they were there. To use them you had to use the clutch to move the shift lever up to the position where second would be on a regular stick shift. You shifted from First to Second by lifting your foot from the accelerator. First gear was very low. Second was a reasonable step up. After you went through those two, you had to use the clutch again to move the shift lever down to the normal position. That made the next two gears available and you went from Third to Fourth by lifting your foot again. Those were the days, my friends . . .
john gill
2001-2013 model year XC70
Feb 9, 2015 04:33 PM
hu5ker555
Jan 3, 2011 04:21 PM
Goat
Mar 27, 2010 02:16 AM
markmac
Jun 19, 2009 07:43 AM
fluidcognition
May 19, 2009 10:20 AM
