Winter/Wet Mode
Old Dec 14, 2009 | 01:03 PM
Goat's Avatar
Default Winter/Wet Mode
My C70's 'W' Button doesn't appear to do anything. According to the owners manual this should be activated while in DRIVE and the button will illuminate as will an indicator on the dash. When I press the 'W' button nothing illuminates on the button or the dash. Ideas?
- Goat
Old Dec 14, 2009 | 03:08 PM
reg's Avatar
reg
There should be an orange arrow on the right side of the instrument cluster when the winter mode switch is activated. Essentially what it does is start the vehicle in second gear vs first. If the arrow is not activated, you probably have a defective switch in the console.
r.
Old Dec 14, 2009 | 03:21 PM
Goat's Avatar
I'll ensure that the arrow is lighting next time I turn the key on. If its not, it may be a defective indicator light in the dash. I saw the indicator mentioned in the owners manual and I believe that it is illuminating when the car starts, but I'll double check. Thanks, Reg.
Old Dec 15, 2009 | 01:17 PM
Goat's Avatar
The Up Arrow indicator on the dash does light when I start the car and it displays all the illuminated indicators on the dash. Looks like it may indeed be a bad switch under the 'W' button. I hope... as that would be easy.
Old Dec 17, 2009 | 08:59 AM
reg's Avatar
reg
I would give that a try as when the auto is running and the "W" switch is depressed the arrow lights immediately.................if it is operating.
r.
Old Dec 17, 2009 | 10:41 AM
Goat's Avatar
Just as further information, when dropping the transmission from D into 4, 3, or 2 the arrow on the dash cluster also illuminates as it should. Is the stealer going to want an arm and a leg for that switch?
- Goat
Old Mar 27, 2010 | 02:16 AM
martin10's Avatar
can anyone give me information about accelerator jam???
it does not work when i put my car on second gear?/?any special reason?
thanks in advance
john gill
2001-2013 model year XC70
Feb 9, 2015 04:33 PM
JKas
Nov 27, 2014 09:46 AM
hu5ker555
Jan 3, 2011 04:21 PM
markmac
Jun 19, 2009 07:43 AM
fluidcognition
May 19, 2009 10:20 AM
