Coolant issue
Old Oct 16, 2016 | 09:33 PM
Mike0909's Avatar
Default Coolant issue
Hello ,
I got Volvo 1999 s80 which runs well but I found coolant missing so I went to mechanic he did pressure test and found there is a coolant leak from heater hose I replaced both hoses and also the radiator cap . My car was running good with no leak for 10 days and I see the coolant low message again and when I park my car I can see there's a leak on the floor. Can someone please help me what would be the problem ? Is it water pump or head gasket?
Thanks
Old Oct 16, 2016 | 10:36 PM
Blade's Avatar
Hi,
Head gaskets usually leak inside the engine, water pump could be the issue but I would check hoses again. The best way of course is to open your hood and also climb under the car right after a trip and see where the water is dripping from, it can help you locate the exact spot.
If you just had some of your hoses replaced those could also be the issue as they are very prone to leak if not installed 100% correctly.
Old Oct 17, 2016 | 09:40 AM
floor of the garage or floor inside the cabin? If its the floor of the garage, I'd give a close look at the outside edges on the radiator where the plastic meets the metal. Not uncommon for a crack to develop along those seams. If there's coolant in the cabin, then most likely its the heater core or its o-rings.
huey3110
Dec 16, 2016 06:06 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
