New Volvo Tech here!
Old Nov 7, 2005 | 02:22 PM
VolvoTechCMC's Avatar
Default New Volvo Tech here!
Hello hello!
I just registered! I am a Volvo Tech with Columbus Motor Company Columbus Ga. Been here since April. Any questions just ask and Ill be glad to help!
Kevin
Old Nov 7, 2005 | 08:12 PM
reg's Avatar
reg
Default RE: New Volvo Tech here!
I'll bet TECH will enjoy you being on board............the poor guy answers just about every question on this forum!!! Maybe he can take a day off and relax.
Reg
Old Nov 7, 2005 | 08:21 PM
fire2havoc's Avatar
Hopefully he can. Welcome to the forum! We're looking forward to your extensive knowledge and expertise.
Old Nov 8, 2005 | 12:48 AM
Thanks Guys! Yeah, Ive been noticing about every post hes been anwsering!
Old Nov 8, 2005 | 01:05 AM
tom1568's Avatar
welcome aboard and glad to have ya. having helpful tech's who know these cars is a blessing....look forward to your help with any matters.
tom[8D]
Old Nov 9, 2005 | 05:51 PM
winhtut's Avatar
Hello, I am also a new member with 99 V70.
I am having a problem. Hope you could help me out. My car has Check Engine Light on. I checked with a code scanner and it showed as P0135 and also B1S1 O2 sensor heater circuit problem. Sensor voltage showed constant at 0.5 volt, not changing.
I have changed that sensor only 1 1/2 years ago.I took out the sensor and checked the circuit. It showed 5 ohms and OK. But when I checked the heater voltage supply to sensor it showed only ~9.5V and found 2.5v between car ground and supply ground. The sensor output showed between 0.4 to 0.7 and changing when I tested without connecting to the socket.
I suspected the ECU has some problem as the O2 sensor supply is coming direct from ECU.
My question is what is my options? Can I buy an ECU, found in the internet for sales, and replace or only the dealer can do this kind of repair?
I will appreciate your advice....
Old Nov 9, 2005 | 06:48 PM
If you are only showing 0.5 Volts the sensor isn't sweeping it should sweep from 0-12 Volts when running.
The Ecu CANNOT be used out of another car. Also if it is a new one the Dealer will have to program it. Which means you will have to tow it there to get programmed.
Old Nov 9, 2005 | 08:29 PM
First off there is a ECM upgrade that may fix that! Have you had the dealer run the codes? Maybe different codes in our PC. If the ECM upgrade has already been done, Replace both sensors. Its hard to tell which sensor is actually bad cause they read off each other. From Volvo they are like 230 a Piece! I just finished up a 99 S70 the other day that i ended up having to replace both of them.
Its a pretty rare occurance that we have to replace the ECm to fix sumthing.
Old Nov 9, 2005 | 08:43 PM
ORIGINAL: VolvoTechCMC
Agreed The only time we ever had to replace the ECM was because it was struck by lightning (The car that is)
Old Nov 17, 2005 | 12:38 AM
gordon368's Avatar
is it bad to the use the turbo in a volvo, like often ? i own a s80 t6 2001, and am young to own it lol, and i use the turbo so i was just wondering.....
also my SRS airbag, service urgent message came up, any idea what that is? thanks
Old Nov 17, 2005 | 12:43 AM
The turbo's are made to be used IMO.
I am like you I love POWER and I drive all my cars Very hard.
In my Mustang 5 speed I take 2nd gear to 90 MPH.
I always push to the Max at all times.
Old Nov 17, 2005 | 12:45 AM
gordon368's Avatar
Im not sure what IMO is ahahah, is that basically occasionally?
ya i brought up my t6 up to 142 mph, and its sooo smooth, no virbrations !
Old Nov 17, 2005 | 01:03 AM
IMO= In MY OPINION
They are made to be beaten!!
Old Jun 1, 2006 | 01:53 PM
eddie's Avatar
my 740 cuts off driving down the road let it set for a few min. and it will start again and run for a short dist. or may run for a day you never know how long it will run
Old Jun 2, 2006 | 05:05 PM
cbevis's Avatar
The SRS light will come for two reasons...the fuse is bad or you got tapped on the front end. There's probably more reasons but those are the obvious ones. If you got tapped on the front end and your sensor is pushed in a little, it's very expensive to fix ($1600 on a Volvo 240). The fuse is less expensive. Good luck
JimZB
Mar 10, 2014 05:58 PM
Ed Hall
Mar 9, 2011 03:47 PM
Adrenalin540
Nov 18, 2008 06:55 PM
crunch5868
Feb 29, 2008 11:19 AM
Shelbyz4u2nv
Apr 23, 2007 10:58 AM
